From Photobucket [JunkOSC; 'Goggle' Photobucket to find it, then sign on to Photobucket and upload your pictures. Use the 'Direct Code' found on every picture uploaded, and click/copy that into the box in your post that you will see if you click on that yellow and black icon above every post] Clear as mudd?
Remember to only pick the 'direct code' and that should make make a larger picture anywhere in your post. After the picture is posted in the message, you can keep adding text or another picture if you click on that yellow/black icon again. You'll have to delete the HTTP:// part. And then place the curser, and click 'paste' again for the second picture you want posted.
skip.
