Pics from Walt Dupont
Mike in AZ
"My latiest sneaky little shoe string engine. Going in a 27 glass roadster. Just a .030 over 3-3/4 stroke, 1007B track cam ground by Pete in Washington, EAB heads milled .040, Merc intake with throttle bores bored out 1/8in. 283 Chevy carb, T-5 trans.".....Walt
nice motor Walt, I'm hunting down a good canidate for a winter/spring rebuild. Looking to drop my motor in the frame mem. weekend!!
Walt: It's easy enough to load your own pictures now. Probably easier than sending them to Mike!
How can you make your reply go under the reply someone else has made in the middle of a thread? Walt
I don't think you can Walt. Probably the best thing you can do is click on "Quote" first and that will bring the message that you want to respond to into your new message box, like I have done with your message on this post. Then respond to that message and click on "Submit Reply". JM
