Pickup floor bed
arefftx
There are 2 options for a pickup floor bed with or without the metal cutout. Will either of these beds work in an original 1929 pickup?
If you install the bed on a model A frame, you need the metal piece to clear the rear frame crossmember, otherwise the wood would hit the crossmember. This is why Ford put the metal part in the bed. BTW, Ford used a piece of webbing riveted to the underside of the metal plate to prevent rubbing and squeaking. If you don't use the metal piece and raise the whole bed up a little to clear the crossmember, the rear fenders and splash aprons wont fit right.
Rusty Nelson
Thanks Rusty & Ronn:
I understand how this will work. I took a 5/8" plywood out of the bed that had some 1/4" shims to clear the crossmember! So same story with the new boards.
Thanks
Alan
