30A
Here are some answers for you.
Good luck
Bruce
Works good
Lasts long time
2. Rivets are soft steel as used by most manufacturers, unless noted. Ford body rivets were primarily Brazier Head with some Round head in non-visable locations.
3. Body rivets are usually installed cold with a "waffle" tool. Frame rivets are installed hot. Waffle tools are not used on frame rivets.
4. Do not confuse a flat head rivet with a countersunk head rivet, rivet shapes are different from screws.
5. If a rivet is too long, cut it with a saw, if you grind it and quench it. It will harden and you won't be able to install it.
6. When sizing a rivet; add the thickness' of metal to be joined, then add 1 1/2 times the diameter of the rivet to the length to allow sufficient metal to form a regular round head. You may want to experiment to get the best results.
7. Rivet diameters: rivets will expand slightly when installed. If the hole is more than 1/32 larger than the rivet to be used, however, the hole should be welded and redrilled or a larger rivet should be used.
