I am looking hard, and I am an immediate buyer for a 39 or 40 Mercury block or complete engine. They have the fully machined intake manifold surface, round center water passage, recessed area immediately above distributor, and 3 3/16 bore or over that if already bored. If you have one you think may be a Merc, let me know and I will narrow it down more. I am a ready buyer. Thanks, PHIL SPAID
Hi GB,
Are you the fellow I saw a couple of years ago on American Pickers? If so, I think Mike and Frank bought a '37 Chevy from you. Good Show. I like it.
Al Hook
These engines have been 2 1/2 miles from my home. The seller is a friend of mine. All the engines and parts belonged to his father in law . Seller is a die-hard chevy guy forty years old and was cleaning out his shop. The father in law had a lot more blocks but junked 14 of them and kept these. The H model six is a runner and recently rebuilt, but pulled for a small block in a '51 panel. The complete 59 ab is stuck, but has clean cylinders, full cross hatching and was obtained from an 88 year old man who had it rebuilt and later installed yet another small block chev. It sat under his workbench for years and unless I am way off base, this engine is only lightly stuck. It is very clean inside. Has a crab distributor and we pulled the heads to look inside. The bare blocks all have labled cranks and caps are installed. This is the same guy I got the Sioux and Van Dorn valve grinding equipment from. These tools were also his FIL's. Some of the cranks have floating bearings taped on and there are boxes of parts. I even pulled my tonner panel out into the rain so I could park this load in the shed until I can get it sorted out and unloaded.
After I had accumulated 4 know good flatheads, I decided I had enough. Sadly, that's not the end. Since then a '56 Chrysler hemi and a '49 Olds rocket have followed me home. I just hope I don't run into any nailheads or "Baby" (Dodge/DeSoto) Hemis. (A 302 "Jimmy" or a 320 Roadmaster would also be a problem.
