N Nick in Fayetteville Senior Member Apr 28, 2014 #1 On the 49-53 pick up truck intake, there is an extra vacuum port. It is located at or near the base of the carborator. What is it's purpose??????
flat-v8 Well-known member Apr 28, 2014 #3 I would think it is for the distributor or the windshield wiper motor, I don't have that year truck, just my guess!
5 59ab Senior Member Apr 28, 2014 #4 That manifold is used on trucks that have vacuum brake boosters also. That is where the booster gets it's vacuum source.
N Nick in Fayetteville Senior Member Apr 29, 2014 #5 Thanks 59ab. Your answer has to be the right one. I knew it wasn't for the wipers or distributor. I had that much figured out.
F FordCustom Senior Member Apr 29, 2014 #6 My 50 model engine has "one" vacuum port that I have seen. The one at the base of the carb, and it was hooked up to the wipers. edit: aside from the obvious steel line, going to the distributor.
Ross F-1 Well-known member Apr 29, 2014 #7 The one to the right is the larger brake booster port, the one on the left is for wipers Attachments Vacuum Ports.jpg 58.9 KB · Views: 19
