pic attempt
I chose this picture from your Photobucket album because I liked your ignition switch.
When you are in your Photobucket album and you move the pointer/icon over a photo wait for the window to appear around it with the link codes.
Next choose the code you wish to use, I always choose the IMG code. to choose the code, left click in the rectangular box to the right of the words "IMG code" the word "copied" will appear briefly. You now have the link code for that photo copied.
Once back to the forum of your choice, in this case Fordbarn, type your post and wherever you want to put the picture, move the cursor to that spot and then right click. From the drop-down menu that appears, right click on "paste" and the link will be placed in the post. To make sure that you have done it correctly you can always preview the post. There is also a test section on the main forums page where you can try out your picture posting skills, it is a good place to try out all of the different things that you can do with this forum.
Remember though, if you move the location of the photo (i.e.- from one album to another) the link will be disabled. Hopefully this was helpful for you, good luck.
