This is the hardware that came with my top frame. The large head carriage bolt isn't correct for sure. The wing nut looks antique, but don't know if it is original or not. These are the 5/16"x18 course thread also. Tacoma Screw has large head bolts, They are better pictured on Amazon. They are called elevator bolts. The tops are not rounded, they are flat. Would need to cut one side flat to match the iron bow end, and remove the square shank on underside of head.
