I agree with Mr. Higgins above. On my last restoration, I was advised by the alignment shop that the front axle had a slight forward and rearward bend on each side of the axle - not noticeable to look at, but apparently enough to alter their ability to provide a proper alignment without bending the axle back into shape. Fortunately they were set up to bend solid front axles as well (buses, dump trucks, etc.), so after several hours, were able to properly align the front end. Be prepared though to cover the cost of a more expensive type of alignment - in my case it ran somewhere in the $350 - $400 range. I've done this type of alignment with all of my cars, and once completed, there is no "wandering" or excessive tire wear. For years, my '29 phaeton drove well without shocks even (it now has them), so in my opinion, if the front end has been properly rebuilt, there should be no need for panhard bars or other compensating hardware. Good luck with the final finish work on your project.
