I'm trying to install a Petronix ignition, and getting confused with the wiring. The car is still 6V positive ground, 59A engine. The wiring diagram is referencing positive and negative terminals on the coil, but the coil terminals say "BAT" and "Dist". Then off of the ignitor the black wire goes to the ignition switch wire, which would be switched ground?
Please help a dumb guy out.
