Bubba, you mention the "threshold voltage". Yesterday when I went out for my weekly "exercise the flathead taco run", the flatmotor did not want to restart initially. After warm up, it always starts instantaneously. I checked the fuel pressure gauge to confirm I had that then checked the connections on my Bubba built Pertronix Chevy distributor. All seemed OK but it was if there was no fire. A passer by offered to check the spark while I cranked so we pulled #1. As soon as I hit the starter, she fired off. So, I'm trying to figure out what could be going on. The battery is about 3 years old and it was a pretty cool morning, if it is getting near the end of its life, could it have been short on that "threshold voltage" enough to not want to fire initially?
"Check the cranking voltage while cranking cold and see what it drops to ???"
Is this process as simple as putting a voltmeter in the line that goes to the Pertronix unit? I'm thinking I should disconnect the unit, take that wire and connect it to the + side of a voltmeter, - side to the frame and crank to see what registers as the starter turns. Of all the plans you've ever read, is this one?
Really a voltmeter at the battery terminal willusually work just fine.
Might want to compare the voltage at the battery and atthe positive side of the coil.??
Hello Bubba, how about a capaciter for the 6vposgnd unit to absorb the spikes?
No ballast resistor with the 12 v Pertronix. Also, just want to get the voltage reading while the starter is cranking, engine not running.
