Bob, An even worse problem with original 1932 to 41 helmet distributers is the coil on top of the distributors operates on 4.5 volts through the under dash resistor. Voltage here is just to low to trigger any Pertronix unit even a 6 volt one. There are modifications that can be done like a remote coil conversion and change to 12 volts but this takes away the originality of the vehicle. Other issues with some electronic ignitions on early ford V8s are the spark plug leads metal conduits cause some kind of impulse spike into the electronic unit and damaging it. Nothing wrong with the original 40 model ignition system if it is in good order. In my opinion, leave it alone. Don't fix what aint broke. Regards. Kevin.
