Grumpy Rick
I just bought a Pertronix Ignitor (1281) which fits most Ford V8's 57 and up. It is for my 55 T-Bird, which is 12V, and now has a rebuilt '60's distributor. I also got the matching Pertronix Flame Thrower coil (40011 1.5 ohm).
This is preaching to the choir with most of you, but there may be another dummy out there who will benefit from the following.........
I just got off the phone with Pertronix tech support, which answered my questions about resistors.
The instructions for the Ignitor state that if the car has a resistor, to use it with the Ignitor. The instructions for the coil state that if the car has a resistor, to remove it.
Per tech support, some cars come with external resistors, some have internal resistor coils. On old cars they sometimes get mixed and cause ignition problems. The Pertronix coil has an internal resistor, and therefore I should remove the original external resistor. If I had used a stock original coil with no internal resistor, I would use the external resistor.
For the record (Amazon FAQ has it wrong)you should use a 1.5 ohm resistor coil for 8 cyl., and 3 ohm for 4 cyl.
I also asked about spark plug gap. They said when using the Ignitor and the Pertronix coil, you can increase the gap 5-7 thou.
One last thing.....the box for the Ignitor says it is made in the USA, and the Flamethrower coil says it is made in Mexico.
Hope this is of some help.
PS: Perhaps other Pertronix related tips could be added to this thread.
