Yes, they run fine. Whats the concern?
I thought I had read some folks had problems with the 6 volt version. For the life of me - now I can't remember the details.
Hello Russ, where and when did you get your P setup. I have a 12v on one of my cars that seems to do well but I remember a detailed discussion from one poster (Rumbleseat) to the old board that had many problems with the 6v version.
Has anyone had any good/ bad luck running a PerTronix electronic ignition in a 6 volt 21 stud? Did it take anything special to make it run? Thanks.
You might check with Bubba's Hot Rod Shop and see if he has anything pro or con to say about Pertronix. He may also be able to help you get his electronic ignition in your helmet dizzy. Click on the link below. JM
http://www.lindertech.com/bhrs/services.htm
