mshmodela
Well appears the last around of rain has washed away the broad salt and I have a pertronix 40111 1.5 ohm 6V coil --epoxy filled to try out (suspect my oil filled coil might be my intermittent issue). With this coil, I believe it has a higher output voltage and would my spark plug gaps need changing? I have a standard head (compression wise)
https://m.summitracing.com/parts/pn...BN3cgfxpkeIeGekFDNpF2OHNtHxEqySDBMaAqC88P8HAQ
