pertronics
frank long island
has anyone ever had the magnets fall out of the rotor on a pertronics unit took the ranchero for the headliner car ran like crap i know it needs a carb but hardly enough power to load on the dolly looked at the plugs most were wet and black pulled the cap and found 4 out of 6 magnets were stuck to distributor shaft this explains the loss of power
I have been running Pertronic ignition modules in several of my cars/trucks for over twenty years.. I have never had a problem with any of them..
Like everything, one should follow the 'Directions on The Can" when installing the modules.
I had the part that slips over the cam have casting dimples that hit the plate below. I used medium sand paper on a flat plate to hone it down just a bit.
You should, I would, call Pertronics and insist on a free replacement.
