Persistent Leaky Fuel Shutoff Valve
I rebuilt my original valve 3 times and it still seeped. The carb had the original ball type float valve. I bought a new tank shut off valve from who I can’t recall. Still seeped. I put in a new Viton needle and seat float valve and no more leaks. That was 5 or 6 years ago. I haven’t driven my car for a couple months and the gas is ON right now in my garage with NO leakage! I just walked out to check before I wrote this reply and it’s dry as a bone! And the tank is 3/4 full. I don’t think the valve design is a for sure never seep design. Back then your garage floor was gravel. At least my grand fathers was. Boy I miss that oil gas dirt smell!!
I forgot about the Viton needle seal. Sounds like a great idea. I will try that as well.
I have been trying to stop the seepage ever since I got the car: have rebuilt the valve and carburetor. Carburetor runs fine except for the seepage. And the main shutoff after rebuild works well for a few months, then becomes stiff and seeps. I trust this ball valve with the nylon seals will fix it.
I ended up installing option one. I didn't have to shorten the fuel line between valve and firewall. And I positioned the valve with slightly shortened handle so it would not hit the metal channel under the speedometer cluster.
Here is the final installation.
My coupe sat since the early 60's. I got a packing from Macs replaced it and 3-1/2 years later no leaks. I've turned it off/on at least 200+ times.
Looked at it this morning. Dry and no drips. Ball valve is easier to turn and moves as smooth as silk.
Celebrated with my wife on a 60 mile tour this afternoon. Temperature outside hit 90 degrees and cruising for many miles at 50 mph she did not overheat (previous problem fixed).
Life is bliss....
