pedal help
rob63mess
I have a couple of issues with the pedals on my T. First, there is a lot of free play on my brake pedal.....the brakes work fine but the pedal doesn't return to the full up position. And, the "go" pedal does not pop up when the lever is thrown forward.....the ****** seems to work fine and shifts well. Can anyone give me a heads up on how to fix these issues. As always, Thanks
Rob
Mine is like that. The cams on the pedals are worn. The linkage to the clutch is worn too. Pedal shaft holes are worn. If you find yours are worn the same way replacement cams and over size pedal shafts can be bought and the holes for the linkage welded up & drilled freshly.
