pcv
crazy redneck
I saw a picture of a pcv that was fitted into the road draft hole on the intake of an 8ba.Anyone use this set-up?Wonder If this any good?
I think there are a number of threads on this already. Do a search. It is something that I want to do sometime, too.
Have had this setup for a number of years and it has worked well by eliminating the stink and the added advantage of reducing oil seeping from the main seals because of the negative crankcase pressure being created.
That's what I did... I took a freeze plug, brazed a fitting to it, and for looks put it in upside down... Works well.
Karl
