Lawrie
I,m building a 265 ci engine, for a spare for the 33
I,m trying one of the Big 97 carbs,the only manifold I have that will allow the throats to be bored out to fit the larger carb throats is an alloy one from an 8ba.
it has a 3/8 npt port under the carb flange that conects to both barrels,and I thought this might be a good place to plug in a PCV valve,the other end can go into the front of the manifold where the oil fill tub used to be.
Any ideas what valve to use,and is it a worth wile addition.
Lawrie
Lawrie
