Re: PVC Valve
The late model engine is the easy one to modify. Use a new filtered oil fill cap. Remove the intake manifold, and drill in to the bottom until you are in to both runners equally. Drill to 3/8 pipe size, then tap for same. Remove the pipe from the crank case, and shorten it by two inches, then make two angled cuts 2/3 through at an angle leading down. Weld, braze or silver solder light sheet metal in these cuts to act as baffles. Reinstall the pipe, with a 302 Mustang PCV and grommet, the grommet fits just right. Use a 3/8 90 degree brass fitting with a 3/8 hose barb in the intake manifold, then at assembly, connect the two with good quality hose. Reinstall the outside pipe to make it look stock, and you will have a PCV where nobody can see it.
