Why is it not worth it when the environment, oil and internal engine stays much cleaner with a properly operating PCV system? I, along with many others, know first hand adding a PCV is well worth it, fact not opinion.
I all honesty this is one of those subjects were its rare for even two people to fully agree on any aspect of it.Some time back i wrote about putting a pcv valve on a ford flathead. I've gotten some answers but not about a 1948 Merc engine. Is there a road draft tube on this engine? How can i hook up a pcv valve on this engine???
HELP.
BTW
Iv successfully built a (hidden) PVC system that works perfectly
The extra port on manifold, I think, is a big one (3/8 pipe??) with two tiny drillings into the actual passages...is that what you have?? That would be a port for truck vac brakes, and a logical connection. I've seen those plugged on some manifolds, on others just a flat area to allow the drilling.
Mine matches drawings that are in 1943 editions of Canadian military Ford manuals, with the plate under carb hooked to the line from PCV mounted vertically below front of carb and connected to the fitting on side of gen stand.
I discovered recently that WWII Jeeps used a VERY similar PCV that is now available in repro. I'm going to get around to buying one to compare.
My setup, the most complete I have found, is on the same Canadian aluminum manifold with 3-4 bolt capable carb stand. I think the 4 bolt may have been for some British Solex rig, pure guesswork on my part. There was considerable effort to keep spare part interchangeability between Canadian, US, and British flatheads.
The plate is a thin die cast piece that lives below carb, and at the front it has a threaded hole for adaptor to the steel line. This fairly large opening dead ends and is drilled with two little holes Veed out to meet both sides of intake.
I built one for a pre-8BA Thickstun that tapped into both plenums (underside of manifold). I made a vent cap with filtering material.
Someone said earlier that in theory the pcv should only open at low load cruise. This is incorrect, most are open all the time, low load (high vacuum) has them in a minimal open position (less flow), high load foot to the floor stuff (low vacuum) opens them more. .
If you all had ever seen what happens when blowbye is ignited in a confined place (like in a motor) you’d know what the pcv valves #1 job is …. it’s a check valve
