Pcv valve effect on load o matic
modela4shane
Can a PCV valve have any negative effect on the load o matic distributor on a 8BA. Could the ported vacuum signal to the distribulor be diminished using a PCV connected to the wiper port on the intake? Any thoughts, Thank you.
Ran a PCV for a couple of years while using the loadamatic with no issues.
PCV uses manifold vacuum not venturii vacuum.
Does it effect it when you turn your wipers on??
