Patch panels
EMS rockers, floor pans, inner rear quarter should fit. The front quarter and outer rear quarter are where the merc is different I think
Found this new stuff by 3M, Cavity Wax, 08552 and 08551.
Wished they coated my patch panel when insatalled, now have a bit of rot under paint at horizontal, seam?
Cavity wax is a must. hit all the welded seams with it too. moisture works its way in between the spot welds and rusts.
get into the rockers... there is a cowl plug in the front shoulder where the front fender bolts up. you should be able to put a 360 degree nozzle on some tubing and shoot it in there.
attached is a shot of the access hole before repair.
I've had my victoria done. I'll rust before it does.
