I ended up with some parts I have two headlights which I believe are both 1932 Ford however, one has a hole on top for a turn signal and a hole for the third wire in the base. The only other difference is the rivers in the bottom, one has flat head rivers and the other has rounded head rivers.
I also have a pedal assembly which I thought was 1932 as well. The parts were all labeled as 1932.
