Part name/number?
naijkee
Hi!
New upholstery being made for my Ford 1939 and now I need your help! What is the name (or number) for the part in the picture ? Mine is half as it is, I need a new one. Been trying to find it at Macs and C&G, but cant find it. Or maybe Im searching for the the wrong part/name ��
Thanks guys!
Interior trim type parts may be hard to find at normal parts suppliers. May need to try upholstery supply shops.
Hi!
Thanks guys!
As I recall that piece is a stainless trim strip(sometimes called a feature strip) and it is not likely that it is reproduced. They would be tricky to make and the call for them would be minimal. You probably need to run a want ad for a used one.
Might start with LaBaron. Kube might know a good source.
http://lebaronbonney.com/
Those have never been reproduced. IF you are lucky enough to find a good pair, pay whatever is being asked as you are unlikely to find another pair.
Second option? If you are not doing a true restoration, simply do not bother installing them. Your LB door panels will not have holes for them so there is no worry of covering anything up.
