Parking brake adjustment bolt?
lotsagas4u
Hello, working on a 1915 T that has sat for 40 years. I am missing the clutch adjustment bolt that rides up on the cam. Does anyone know the correct length for this bolt? Thanks for the help.
Most of us turn the bolt over so it rides on the head not the end of the bolt at the threaded end. I round the head over, so a sharp edge does not hit the cam. Also squeeze the handle so the pawl does not ride on the teeth when you pull the lever back. Don't forget the lock nut. Can be on either side of the lever, as long as there is one to keep the bolt from backing out. (Been there!)
