panhard bushings
Topher5150
I bought the panhard bushings for my 47 coupe from macs (part number 64-15742) they are a bit wider than the bracket. Is this a part that gets smooshed into place I tried a few different ways but it seems to come out the same. Also what size bolt holds the bar to the bracket
I also bought those bushings from mac's and I had to cut them down to be able to fit them. I am thinking of making my own (casting urethane in a plaster mold. Also the bushings from mac's are to soft!
Check with energy suspension. They have all sorts of urethane bushings and you may find some that will fit. I recall that years ago I used some urethane bushings from a rod shop that fit a four bar front end that worked on the 42-48 sway bar.
Thanks, i looked at my 34 for roadster project with four bar front suspension and you are right those bushings seems to fit on the panhard rod on my 46!
