Joe Altieri
I am having "brain fade".
When properly installed, is the metal panel above the windshield on a '30 coupe flush with the wooden header, ( and the underside of the visor) or is it about 1/4 inch below the wood?
Does the welting cover the gap? Is the welting fastened under the top edge of the header cover or under the visor?
There are two bolts passing vertically through the lower portion of the header. Do these bolts go through the metal cover, or do the just sit under the metal cover?
My guess, from a faded memory, is that there is a gap and the welting is fastened under the top of the panel.
Any help would be appreciated.
Thanks.
Joe
Thanks.
Joe
