Here is an idea if you can keep it out of the bearings.
properties, making a temporary, brittle repair.
[edit] Automotive repair
Sodium silicate can be used to fill gaps within the
head gasket. Commonly used on aluminum alloy
cylinder head, which are sensitive to thermally induced surface deflection, and can be caused by many things including head-bolt stretching, deficient
coolant delivery, high cylinder head pressure, over-heating, vapor-lock, etc.
"Liquid glass" (sodium silicate) is added to the system through the radiator, and allowed to circulate. Sodium silicate is suspended in the coolant until it reaches the cylinder head. At 100–105 °C sodium silicate loses water molecules to form a glass seal with a re-melt temperature above 810 °C.
A sodium silicate repair will last two years, sometimes longer. The repair occurs rapidly, and symptoms disappear instantly. This repair only works when the sodium silicate reaches it's "conversion" temperature at 100–105 °C. Contamination of engine oil is a serious possibility in situations in which a coolant-to-oil leak is present. Sodium silicate (glass particulate) contamination of lubricants is detrimental to their function.
[edit] Homebrewing
Sodium silicate flocculant properties are also used to clarify wine and beer by precipitating colloidal particles. But as a clearing agent sodium silicate (water glass) is sometimes confused with
isinglass (a form of
gelatin prepared from
collagen extracted from the dried
swim bladders of
sturgeon and other fishes). Eggs preserved in a bucket of waterglass gel, and their shells, are sometimes also used (baked and crushed) to clear wine.
[6]
[edit] Car engine disablement
Sodium silicate solution is used to inexpensively, quickly, and permanently disable automobile engines. Running an engine with about 2 liters of a sodium silicate solution instead of
motor oil causes the solution to precipitate, catastrophically damaging the engine's bearings and pistons within a few minutes.
[7] In the United States, this procedure was used to comply with requirements of the
Car Allowance Rebate
