glennpm
Hi,
I've been working on restoring a 38 steering wheel. The wheel and horn button came out well but disappointed in the dull finish I got from a rattle can. Even with a couple of wet coats, the finish is dull. The single can delivered was $35!
The part is the headlight switch with rod. The pot metal part has a pebble finish. I removed all the old paint, sanded with various grits, used filler type Rustoleum primer and then the final coats. The first picture is closer to the real color and is a match for my car's exterior.,
I'm thinking about sanding with very fine scotch pads that I have and then maybe 1000 or 1500 wet/dry paper, finishing with clear coat.
Suggestions please.
Glenn
Suggestions please.
Glenn
