Russ/40
Regarding the materials used, specifically polyester primer surfacer, and epoxy primer sealer, what is the proper order of use? Is it proper to start with a coat of epoxy primer sealer/surfacer, Work that material some, and progress to the polyester for greater build, then finish with the epoxy sealer, prior to finish coat? I am using TCP Global's "Kustome" series of finishes. I really like the epoxy, and it does build well if not reduced, but for time sake I have been going to the polyester for minor leveling. I am planning on relying on mechanical and not chemical bond for finish coat, as by the time I have finished body work I am way past the ideal recoat window. What say the experts.
