Painting Bottom of '30 Radiator Shell
dmaxweb
I'm ready to paint the bottom of my restored radiator shell. There are several 'reveals/ridges' from the s/s face of the shell down to the flat area. Is only the lowest flat area painted?
Masking the tight curves is a pain especially around the crank hole. I've tried overlapping with green frog tape and triming to the curves with a razor blade and ended up with paint creeping under and bits of paint coming off with the tape and not a clean edge.
Would some fine line masking tape be best to use and then mask back with regular masking tape and paper?
I'm using spray acylic laquer and don't want to end up with a ridge of paint. Does it make a difference how long to wait before removing tape after spraying?
Thanks
Ford used an overlay template and sprayed it which left soft edges. You can carefully cut one out of some heavy paper stock like file folder material and tape it down. Make sure the edges lie flat so you get an even "overspray" look around the paint edge.
