Pin striping is an art. Watched a real life stripper do the fancy work on a car one time. The attached video, while not a car, shows what a skilled hand can do. https://www.youtube.com/watch?v=UsTIMxeO_ng PS, turn down the audio.
rotorwrench
"Not all were striped with a brush. A few branches did use the wheel striping tools."
I couldn't find that in my library. Would like to get a copy of the publication if you don't mind sharing.
Is it from the Restorer 1975, Sept./Oct.?
I also recall that photo, but all is not quite what it seems. It does show two pin stripe men, but the main one appears to be imposed into the photo [ look at angle of his shoes to the floor] but other man looks correct.
So, when were the bodies pin striped? Before the bodies were mounted on the chassis or at the very end of assembly? Film evidence shows pin striped bodies being placed on the chassis.
Now that's a good trick, must have had loooong arms.a pin striper working on both sides at the same time
a pin striper working on both sides at the same time Now that's a good trick, must have had loooong arms.
Yeah, it is a curse! [ million dollar memory] but handy at times. I read in a follow up article that the man striping the Tudor was actually from a 1936 photo & imposed into the scene.The man with a million dollar memory
I looked up the Sept/Oct 1075 Restorer and you are correct although I seem to remember the photo being from the driver's side and a pin striper working on both sides at the same time. My memory is only worth 2 cents![]()
TOB
