Gumpy,
I have used several of those sanding discs from HD to remove paint down to bare metal without 'sanding the metal away'. They are made by Norton and called 'Rapid Strip' wheels 4" x 1" with an arbor to fit your drill motor.
They work great and as they wear down you can use the smaller wheel to get into tighter curved areas.
Hopes this helps, Jim
