I have one of the water pump nuts with the seal in the front. Everything else on the pump is original. Do I need to add packing behind it? Are these an improvement over the original nut?
And add some grease. The seal will guard against leaks by itself. You won't need packing until it starts to leak. Get your packing from a Model A Ford suppler.
