HDowse
I'm working on the brakes on this survivor '40 Fordor. The front brake hoses were so bad they were solid, no visible passage for fluid. The steel lines are OK now that they've been blown out. New grease seals all around, front shoes good, rears covered in grease, to be replaced. Now to my question: the front hubs were filled with grease between the bearings and the bearings are fine. I cleaned out the old grease in the space between the inner and outer bearings. Should I pack that void with new grease? Thanks for the continuing help on this great old car.
