Bill, It sounds like it might be time to rebuild the gauge. Run your finger around the gas portion of the fuel gauge and give it a sniff. You will probably have a little gas on your finger. If so, changes are you have an old cork gasket in the gauge.... they don't do well with ethanol gas and eventually start leaking. I did a "partial repair" of mine years ago. Be certain to use a good gauge removal tool (there are special tools for this) so you don't scratch up the gauge while removing it. The repair is easy but is a bit of a pain if you use the wrong removal tool. I often keep the tank less than 3/4 just out of the fear of this leak reoccurring. I hope this helps. - Seth
In all the years we have owned Model A Fords, I have “never” filled the gas tank over 3/4.
There are many reasons why not to fill it, and only one reason to fill it, (mileage). Enjoy.
It would seem if it were the gasket of which you speak, then it would seep as long as there was gasoline behind it.
Also, maintaining that you are correct, where does one obtain the tool of which you speak?
THANKS! Bill
Bill, the reason it doesn't leak all the time is because the gas doesn't reach the gauge glass until it is over ¾ full. Under ¾ full, no liquid gas behind glass, just vapor.
The "tool" is available from all of the vendors as well as the "rebuilding" kit..
Another very recent thread on this.
https://www.fordbarn.com/forum/showthread.php?t=234548
EXACTLY! If touring, one doesn't have the luxury of towing a tanker truck behind you! LOL![]()
did a search and couldn't find this one.
When tank filled to full the stink of gas fumes will practically drive a guy out of the car! P.o. Said he'd only fill to 3/4 tank. While this works great around town, not so well when touring!
Did a search and couldn't find this one.
When tank filled to FULL the stink of gas fumes will practically drive a guy out of the car! P.O. said he'd only fill to 3/4 tank. While this works great around town, not so well when touring!
Solution???
Bill
Solution???
Bill
"p.o." ????
