1965 Mustang
This has probably been addressed many times before...
My 29 A (with original motor but with 4 blade fan) constantly blows all the coolant out the over flow or the top of the radiator. I have flushed the cooling system several times, and the ignition timing is correct. When the engine is running with a full radiator (before everything blows out) there seems to be a lot of air bubbles coming up to the top of the radiator. I am thinking exhaust or compression pressure is in the cooling system. However engine compression is good and there is no steam out the exhaust pipe or coolant in the oil or oil in the coolant.
Ideas?
Thank you
Ideas?
Thank you
