I don't mean to rob this thread but I also have a overheating question. I have a 59a engine, new Dennis Carpenter water pumps, Stant 170 thermostats, 50/50 antifreeze. I have checked the timing and it is good. I am using a stock '32 radiator. The car seems to cool fine around town with low RPM's (180-185), but if I get on the highway or gear down for a climb with higher RPM'S it goes up to 210 and up. Any ideas?
Remove the stats, that type restricts the flow of coolant. The pumps you have don't move very much coolant. Make sure you fill the radiator and
have a good working pressure cap. Put the overflow into a recovery
bottle so as it cools down through 155 degrees it sucks the coolant
back into the system. G.M.
