thom
The seller, who is a lifelong, trusted friend, of the '28 Sport Coupe we're buying in a couple of days, assures me that the car has never overheated in the 2+ years that he has owned and driven it. However, a previous owner has installed a horrible looking, gallon jug on the driver's side firewall, above the steering column for an overflow. There is a 3/8 hose from the lower end of the stock overflow tube to the jug and a 5/8 or 3/4 heater hose from the jug toward the ground for a drain. The car has a quail thermometer cap on it. An overflow tank mounted there would not work with a non-pressurized system, would it? That mess on the firewall will disappear on the way home at the first public trash dumpster I see! See the pic below.
Another thing that concerns me a little is there is a grease fitting instead of a filler plug in the top of the steering box. The car steers great. I know people have substituted grease for the 600w lube in steering gears for decades but what should I do? Plan on a tear-down and possible steering box rebuild or at least a wash out and lube change. Reckon damage has been done to the gear if it still operates smoothly? Thanks.
