overdrives
robert dick
from working on British cars half my life i have a few transissions laying around with Laycock overdrives, wondering id anyone has tried adapting one to a Ford ******.
I used a Gear Vendors unit (same as Volvo type). To me a better answer than one of those Mitchell units, as it is smaller, and electrically operated
Hi J
Gear Vendors themselves make these for a closed driveshaft application.
A friend in Colfax, CA has one in a 32 roadster and it works well
Mine is a bit different as I added the GV to the transmission
and have an open drive setup.
Can't seem to load a picture
Yes Robert, I have adapted one (a GV) to a Ford (Jeep) transmission.
Most however, adapt the Laycock type to the driveshaft, due to the
coupling issues
Any good machine shop should be able to help you out,
unless you are that capable. I am not
Jim
They are kind of rare, but if you can find a Pacer, Gremlin, or Hornet overdrive transmission from '75-'77, they used a ford full syncro 3 speed trans with a Laycock type J overdrive. I have one in my roadster and it works flawlessly. I removed the side shift linkage and installed a Jeep T150 top shifter for an original look in the car.
