Habusailor
My 49 custom does not have overdrive, I see a lot of shoeboxes came with OD. What is the best way to convert to overdrive?
Sent from my SM-T550 using Tapatalk
The '51 transmission is a bolt in in '49 and '50 if you use a '51 rear crossmember.
I suspect that you have to drill the proper holes in the "X"-member to mount the '51 cross-member; I don't think they're already there. That might get a little tricky.
