green50
I recently swapped my standard 3 speed trans out for an overdrive trans in my '50 Ford. After going through all of the electronics, wiring(harness from Shoebox Central), relay, solenoid and governor, several times to eliminate them the trans still will not go into overdrive. It also will not even freewheel with the cable control pushed in. So I guess my question now is what, internally, would keep the trans from going into overdrive? Any ideas? Thanks
