What trans. Will work . Will car trans. Work.? Sunshine
This is a 49 Merc O/D transmission in my 1940 Tonner. I fabricated a new bracket to support the transmission and bolted it to the existing cross member and had a new driveshaft made to fit. That was the extent of the chassis mods. It was a straight bolt in clutch and all. We modified an early Ford 4 Speed shift tower to do the actual shifting chores. As has been suggested you will need to locate a column shift to complete the modification. I suggest you also consider the use of a T5 transmission. Do a search here on the site and there will be many threads on that topic. Good luck...
