Overdrive Solenoid's
Jim Griffith
Gentlemen,
Can anyone tell me if there is a functional difference in a 4AR10B-62 and a 10AR10B-62 overdrive solenoid? Are they both 6 volt?
Additionally, does anyone rebuild the overdrive solenoids?
Thanks for your help.
Jim Griffith
Functionaly, all the solenoids work in a similar manner. The Nash & Hudson stuff I've come across all works same way as Ford/Mercury but has different mounting style or bolt pattern and some have longer or shorter actuator shafts.
There are folks out there that rebuild the coils & replace the points on these and there are new replacements for some makes available. The Fifth Ave Internet Garage sells reproductions that fit some models.
Kerby
fifth ave has new replacement solenoids 6volt & 12 you have to tell them the length of your shaft,
Fifth Ave is sold out on solenoids. They are working on doing another production run. No time frame yet. So, it's fix-up time for now on existing solenoids.
