Johnnydidd
I was told that a 6 volt overdrive selnoid will work on 12 voilts without burning out? Has anybody had any expierence doing this. Thanks John
I used the 6 volt on my 53 Merc, which I changed to a 12 volt system, for years, worked just fine. Yes it has power at the terminal, but only goes in the selnoid when you put it in or out of overdrive! It will work.
