Tom Wesenberg
If you have a poor connection in the charging circuit, then the generator voltage can be too high, even though it won't reach the battery. Where did you measure 8.5 volts?
I removed the cutout and removed the cover to watch what was happening. The points closed when the car was started and never opened until I shut the car off. The cutout I have does not look like anything (internally) like I have seen in anything I've read.
QUOTE: When you start the engine the points close and the generator charges the battery, when you shut the engine off the points
open
My understanding is that the generator doesn't actually begin charging until it reaches a certain RPM, usually > 500RPMs. So the Model A cut-out actually cuts in as soon as the ignition is on?
