Hi garyjohn,
With more specific details of diagnostics, you can obtain far more specific responses, like:
1. How did you check the water temperature?
For over than 50 years I have placed a simple inexpensive Candy Thermometer in the radiator opening to check the coolant temperature where it really counts, i.e., where it exits the engine.
2. How did you check the timing? With the 8 million different recommendations written and/or listed herein, and the 8 million timing misunderstandings of Model A owners, plus loose distributor cam backlash movement? Did you ever perform a simple check to "see" if the no. 1 plug fires when the timing pin slips in while the engine is hand cranked clockwise?
3. Generalities offered like, "Had the radiator shop clean the radiator" is not at all specific ...... did he use Klennex and a metal dust pan, or toilet tissue with rubber gloves on?
4. In most cases, overheating in 85+ year old vehicles is caused by a loose slipping fan belt not turning the water pump fast enough; or a dirty radiator which is partially clogged, and/or has too many coats of paint on the exterior. .... and not necessarily in that order.
