Mike/Franklin
Taking apart a 21 stud motor that was Ford rebuilt. Has the tag. Has a set of adjustable lifters. Trying to get the lifters out and dispose of the rest. Big hole in one of the cylinder walls.
Most interesting is an OSCO manifold with a cast iron wedge shaped carb spacer. No exhaust manifolds. Was this a marine application? Spacer is marked OSCO PHILA. Any modern use for this application? Junk? Value?
Thanks ML
Thanks ML
